[SOLVED] Horus with opentx integration
karlmort
https://vimeo.com/197539703
Just for your info.
Here is a video of my setup, you can see the update speed is quite slow.
This is opentx 360N
Best regards
Karl Morten
Ktm250
I tried to upload a video showing how long it took to load the page you wanted but it would not work. So I timed it loading the page 5 times. The highest time was 49 sec, the lowest was 16. The average was 34. Would you please send me the video that your test pilot took so I can see what a normal load time looks like.
Thank you for the message.
Normal loading time is approx. 3-4 seconds with Taranis (page 2). With Horus it is around 15s with the same setup.
So definitively there is something wrong but for sure it can be fixed by OpenTX update.
Ktm250
Karl,
Just looked at your video and I would say that the load time for that page is similar to mine. Yours took about 9 sec to load. I just timed mine on that page and got an average of 12 sec. Can you time page 2 and see what you get?
Bob
Ktm250
Ok. So I guess for now in my opinion it is worthless to try to use it with load times like this. Plus the fact that it locks up with the MLVSS connected.
We have already contacted OpenTX developers to improve it on the Horus FW. Unfortunately OpenTX 2.2 is still in the development, but I am sure that everything will be sorted.
Ktm250
Ok thanks for the support. Please let me know if there are any updates.
There is actually one update right now. It looks like MLVSS sensor is affecting other sensors and everything that is running on the S.Port bus in the similar way as the integration. FrSky is already aware about it and they will fix it.
So actually there are two different problems.
Ktm250
Ktm250
Just wanted to give an update on this issue. I just installed the latest opentx firmware and it seems to have fixed the problem. It is much faster loading the info from the spirit unit and even works well with the MLVSS connected. It is now a usable feature. :)
