Servo's go crazy when saving unit
That's not good. It seems as problem with logging now.
Check this please: http://spirit-system.com/dl/fw/test/spi ... -test3.bin
Jman841
ZeXx86 wrote:Perfect.
Here is second FW for testing: http://spirit-system.com/dl/fw/test/spi ... -test2.bin
Hopefully it will be better.
Thank you very much for your help.
Still having the same issue with the Tx turned on. Very weird. With the Tx off it does not happen and if it goes crazy and I turn off the Tx while it is going crazy, it gives it a positive pitch and the tail twitches very very fast but not large movements. Instead of the big fast twitches from before, not it just twitches a very little amount but very quickly.
All is good once I reset the unit.
Thanks. Does it happen with version test3 as well? Do you see any warning about lost signal in the log after this event?
Jman841
Not sure,
Let me test...
Jman841
Unfortunately it still has the issue.
The first restart after flashing the firmware I could not get it to happen. I turned it off and back on then switched banks.
When I switched to bank one I changed 1 parameter (stick dead band from 9 to 8) and changed back to bank 0. When asked to save I clicked save and then it started twitching like crazy.
Very weird. Thank you for the help/support!
OK, thanks.
At least I know from these tests where the problem is not present.
Another one: http://spirit-system.com/dl/fw/test/spi ... -test4.bin
Jman841
Ok cool,
I will test when I get back home. Went and flew a few packs and the gym.
Jman841
Ok, tested Version 4 and much better!
I can not seem to get it to go crazy after saving or opening any logs.
The only time I can get a weird behavior now is if I have the Spirit plugged into the software and the Tx is on. When I turn the Tx off the tail servo will twitch very fast until it has regained signal from the Tx.
This only happens if I am in the software. If I turn the Tx off without the Spirit connected to the computer it does not do this.
Other than that, whatever you change fixed the problem!
Thank you!
Great!
I think transmitter is sending some weird data (Maybe Failsafe?) but I think it could be fixed too.
I guess you can see extreme value in the diagnostics tab when this happen?
Jman841
Yes, Rx signal lost of corse. I didn't save it but I will next time to send to you.
Thanks for all the support!
