Ok, perfect. It's all set up properly. I will test next week when I return from traveling.
Let's hope for the best! Thanks for the support as always!
Rescue tilt on Logo 480
Problem is solved. The other unit performs flawlessly and flies so incredibly well. Rescue went straight up as expected no matter how hard I beat on it.
Should I trst the other unit in my Goblin 600?
I think it could have been 1 of 3 possibilities.
1. I didn't have the unit precisely aligned on the FBLS tray
2. Static electricity was messing with it. I grounded the boom but the tail case wasn't, just fixed that as well now.
3. The unit has some manufacturing defect.
Please let me know if I should test the other unit on a diff heli or send it back.
Thanks for all the support as always!
Thank you very much for your info.
We will send you new red unit. It is not necessary to send the unit back as you are constantly supporting Spirit and helping other people.
It seems there could be some issue in the unit that we were unfortunately not able to determine sooner.
Your unit can be eventually used to check what is wrong, but it is not required.
You can do the final test with swapping the unit back to Logo, but in case it will be same, then it is clear.
I am very sorry for your problem.
Great, no problem. Thanks
