[SOLVED] Firmware upgrade to 3.1
Could you please do this:
Set General/Position to Horizontal (0°)
Then perform calibration with CTRL+ALT+U again.
Set General/Position back to your original position.
Then check if the problem is solved (possibly after restart). If no, I will send you PM with other solution.
Kennyd
Sorry can’t send 4ds file as the computer I use for spirit setups is not online
Bear with me I’m trying to find a way to get the file to you
Kennyd
Re calibration at horizontal (0Deg) made no difference,
I am using an iPad Online just now , I assume there is no software got iPad ?
Ah, please check your PM.
App for iPad is integrated in the Wifi-Link.
Kennyd
Thanks to ZeXx86 All sorted , again thanks to everyone who contributed
Kind regards Kenny d
You are welcome!
The issue was resolved by resetting calibration data to factory defaults.
urgno
and how is this done ? ;)
With key shortcut, but it is not public, because people would try it without real need to do this.
urgno
true ;)
jjuk
If updating from 2.x to 3.x, is the -U calibration required?
