GT initializing
No, you can find it in the Diagnostic tab - Advanced Flight Logging.
10x
Thanks for quick reply Tomas, so only in the pc set up software? Turned it off will let you know how it goes...
rotorhead51
As Tomas suggested
Turned Advanced flight logger off and it seemed to work, tried several times to initialize, at different time intervals (30 sec. - 30 minutes)and all attempts worked as normal.
so yes, could have been the advanced flight logger.
this is just my findings so far but I thought I would share.
10x
Thought it was ok with flight logging turned off, but just needed a double battery to initialize after standing for 1 hour....
rotorhead51
Same as 10x
tried initializing again after sitting for a couple of hours and had to do the double battery connection to get it to initialize.
Can you attach settings please?
Unfortunately we can't replicate it in any way - tested with around hundred of GT units now - even that all units were without a power for over day.
rotorhead51
here are the settings from my GT unit on my Synergy N5C nitro machine.
thanks
N5C settings.4ds
(255 Bytes) Downloaded 87 times
10x
Flew tonight, still had to double connect the rx power plug from life battery. Produced another log....
The log keeps coming up with " Main Loop Hang Occured" and "Backup Oscillator is Used"
Can you tell me what do these entries mean Tomas?......
Also to add that i can not see these problem logs on the jeti DS12, I can only see them
with the pc Spirit settings software...
Regards Adrian
10x wrote:Flew tonight, still had to double connect the rx power plug from life battery. Produced another log....
Regards Adrian
both of the errors are sign that something was not good at all. The first one is quite important and I recommend to verify wiring.
The second one mean that the unit was partially damaged sadly (the most common is electrostatic hit from a finger). But it can be still used normally, because it has backup part. Anyway this is not related to the issue discussed in this thread.
Can all affected pilots can let me know what receiver are you using please?
10x
Can all affected pilots can let me know what receiver are you using please?[/quote]
Hello Tomas, Jeti REX3 receiver for me...
Regards Adrian
