Hi Asterix,
(the missing settings in the menu are due to the old *bin file.)
Yes, this is what I think too.
(Which version of *.bin-file do you used and which sw-version do you have on the spirit?)
I dont know. This is why I attached it. It is from 09/2019, I dont know which release. SW-Version is 3.4.1.
(I think Tomas can easy explain, which parameters are missing in the *.bin-file.)
Yes.
(And what is with issue, of the "self closing" config menu?)
It doesn't close with the old *.bin,
it closes with the newest *.bin (3.4)
[SOLVED] Spirit Pro after update, problem occurs
Thank you for your details.
It seems that your radios are sending request to Spirit units differently, for unknown reason.
We have to find what is different in your radios/settings. Once we will find and change it, it should work properly.
The real problem was there all the time, but only with recent BIN files that are sending much more requests the problem appear.
While with older BIN files that are sending requests only rarely it works.
Older BIN files will not work well with the recent versions, because they are missing updated parameters. But they will not cause such incorrect closing.
If you can send me all about your radio settings (mode profile) which we can test and settings from the Spirit unit, we will try to replicate the issue.
Hello ZeXx86,
the spirit settings have been sent in my previous answer.
Here is the Protos Spirit2.jsn for the model folder.
<If you can send me all about your radio settings (mode profile) which we can test and settings from the Spirit unit, we will try to replicate the issue.> How can I do that? I am not sure what you mean.
I am flying mode 2, but this is not what you mean.
Once I had Geolink installed with Spirit Pro. Everything went fine.
Later I removed the Geolink. Much later I saw the discussed problem.
I am not sure if this has to deal with it.
If I can help today, I will.
Tomorrow I will go on holidays for two weeks.
Kind regards,
Martin
Kind regards,
Martin
Thanks a lot for all the details,
Have you turned off GeoLink support in the Spirit Settings?
Unfortunnately your attachment is missing
Yes, it is turned off.
I try with a zipped file.
- Attachments
- Spirit Settings.zip
- (544.85 KiB) Downloaded 143 times
and the model file
- Attachments
- 0066Prot.zip
- (4.3 KiB) Downloaded 145 times
Asterix-007
Hi Tomas,
i've send you a small backup from my transmitter.
Thanks for your support.
Ulf
Ulf
Thank you very much!
Tomorrow we will be testing.
Asterix-007
Hi Tomas,
Any News?
The most important question: „Can you reproduce the Issue?“.
Any News?
unfortunately we were not able to reproduce the issue yet.
We are still working on it
