FBL / Software Problem?
nichtdiemama
Im using MacBook Air and the spirit usb interface. Mouse is the original pad of the MacBook.
I noticed that the connection to the Spirit GT is quit slow/laggy when i have other programs running. Since then i close everything and use only the spirit software so it runs well except the problem here.
Thank you, which MacBook Air it is?
We have MacBook Air M1 and it works well with no issue. No slow response at all with any software running.
nichtdiemama
MacBook Air 2020 the small one not m1
kitej
The problem also occurs on Windows 11.
nichtdiemama
Hi
Just checked my second Heli wich has also a Spirit GT. The behaviour is the same. If I use the pitch adjustment and move it slowly up and down the values are drifting more and more. This was without getting close to the min or max of any channel. In Demo mode it drifts only if I reach one of the min and max values like you said.
Hope you can find the problem and fix it.
Kind regards Jens
