Nitro Throttle SetUp - with governor
Scott H
Yes assuming you know what headspeed you want to run.. I don't remember what helicopter this is on
Malc1
Nitro 700 size.
Curve set up and requested RPM used.
I have set the fully shut down throttle point at -40.
If this is at zero once you have added +sub trim to get the engine to idle it seems that you are getting too close to the 15% gov switch on point.
The throttle servo starts travelling towards full virtually as soon as you move the throttle stick.
As it is now there is stick movement before the governor turns on.
