GPS?
alchemy66
ZeXx86 wrote:It could be in 2 weeks if everything will be ready.
Many thanks for the update. :D
You are welcome :)
In the meantime you can check the manual:
http://manual.spirit-system.com/index.php?title=GeoLink
alchemy66
ZeXx86 wrote:You are welcome :)
Yes thanks, I had a good look through it yesterday. Looks very comprehensive. Very excited to get up and running on my Goblin. :)
jgiannakas
Received mine a few weeks back and in process of mounting it on my Goblin 500. Considering the boom is full carbon as is the canopy, what would your recommendation be on where & how to mount?
Thank you!!
FrankFuss
jgiannakas wrote:Received mine a few weeks back and in process of mounting it on my Goblin 500. Considering the boom is full carbon as is the canopy, what would your recommendation be on where & how to mount?
Thank you!!
I don't think that my boom is carbon, but here is how I mounted mine:
https://www.helifreak.com/showthread.php?t=808634
grobjo
I just odered the Geolink, is it possible to mount the Geolink under the boom, because on top of the boom is the pushrod ( Henseleit TDF) ?
Rufus
grobjo wrote:I just odered the Geolink, is it possible to mount the Geolink under the boom, because on top of the boom is the pushrod ( Henseleit TDF) ?
It's a gps,so mounting it under the boom is not a good idea.
It needs a clear un-obstracted direction towards the sky to link up to satellites.
I may be wrong but I'm sure Tomas can chime in.
Sent from my SM-N950W using Tapatalk
Genesis
I just placed an order for one also, pretty excited about trying this puppy out 8-)
Kevin
Now we can answer all your questions :)
Mounting under boom is possible, but it will have some impact on signal quality.
You could use a third party mounting solution for GPS modules that can hold it above the push rod - this would be the best.
Butscher
Hi, congratulations on the finished product.
I have installed it so far and it is also recognized "when exploring the software I noticed with map that the position is not displayed correctly the coordinates are correct but on the map a place that is about 20 km away is displayed as position.
Gesendet von meinem SM-G950F mit Tapatalk
