GPS?
Yogi43
I will check again .....
Yogi43
I'm sorry - you are right, it was the ISP-position. It was probably to warm in my workshop. The actually shown position ist correct.
Butscher
Hi how is it with benches.
Can I couple on bank 0 rescue (coax) with Return to Home with altitude hold and on bank 1 and 2 normal rescue with pitch addition but without Return to Home and altitude hold?
Or is it bank comprehensive so that if more active with rescue applies to all banks
Will there also be telemetry for example
speed
coordinates
Height ?
Gesendet von meinem SM-G950F mit Tapatalk
Yogi43
And just one more question - as stated in the manual, the activated Geolink function can be engaged with the Stabi function. Does this also work with the Rescue-mode (with pitch)?
Example: Rescue-mode is triggered by negative gyro-value and in Geolink RTH and altitude limit between 15 an 20 m is activated. Does the heli ascend or even descend to a height between 15 and 20 m and then return to the programed position?
Yogi43
Yogi43 wrote:And just one more question - as stated in the manual, the activated Geolink function can be engaged with the Stabi function. Does this also work with the Rescue-mode (with pitch)?
Today I will do the first test with Geolink - as described in the manual I have set the Stabi function to Coax and have activated RTH and Altitude-Limit between 15 and 20 m in Geolink
Does anyone have already experience with these settings ? I want to use it as a replacement of the Rescue-Mode.
Yogi43
Yogi43 wrote:Today I will do the first test with Geolink - as described in the manual I have set the Stabi function to Coax and have activated RTH and Altitude-Limit between 15 and 20 m in Geolink
The first test is done - great product!!! I tried a combination of Stabilization(Normal) with RTH and Altitude Limit. The heli climbs or descends into the defined height window and returns to the defined point - great!!
The only thing is it doesn't return to home always with skids to the ground as expected with Stabilization(Normal).
Is this intended or is this a bug?
Yogi43
Any idea?
Hello!
thank you for your message.
in order to work precisely, you have to calibrate the Compass. If this was not done yet, it could be the problem.
It should not matter what mode is selected for RTH. It should work in the same as with Coaxial and same for inverted and same for skids down.
Yogi43
thanks for your message - I did a calibration, as described in the manual, before the mentioned test. But I did the calibration at home - could that cause the problem?
In some cases it could play a role - some buildings contain a lot of steel. It depends on what model is doing. If it is doing a circles, then definitively it is either mounting issue (imprecision) or calibration.
