[SOLVED] Horus with opentx integration
Wow, that is great news. We will be testing OpenTX 2.2-rc9 too.
We will see the result :)
Thank you!
karlmort
https://vimeo.com/202449197
This is opentx 2.2 362N.
Much faster now [emoji3]
Best regards
Karl Morten
Very nice. I hope that they will release it officially soon.
Adrian
[quote="Ktm250"]I can find nothing wrong with the connections. Here is how I have it wired up.
This is without the mlvss
Following the FrSky integration guidance, as I understand the FrSky integration cable is only required on S.Port (telemetry) not on SBUS (Radio Controls), right?
Beside Controls, the SBUS connection is required to power the receiver, therefore normal Servo cable should be used.
Tomas, can you clarify?
Adrian: You are right. But Ktm250 is using small Spirit unit which require the S-Bus integration cable.
On the other hand, Spirit Pro require normal cable.
