[SOLVED] Spirit Aero with Jeti CB200?
stipsi
Hello Thomas
How does it look, is there progress?
LG
Christian
at the moment no.
We are focusing on the new update for helicopters, then we will work on the Aero.
stipsi
ZeXx86 wrote:Hello,
at the moment no.
Ok, thanks.
alcastan
Hi all, wondering with the new 1.4.0 version and supposedly support for 16 channels, is it possible to use with the CB200 and stabilize all 16 channels? all my jets use CB200, want to try the Spirit Pro on one of my jets instead the BD Cortex Pro
Regards,
this is not possible yet but will change soon.
In which way do you expect servos will be stabilized? Do you only need to just make it work as if Y cable is used for one signal and this one is used by for example 4x servos on aileron, second signal on 4x elevator, third signal 2x on rudder?
alcastan
Hi Thomas, I would like it to work as a Cortex, that the signal is sent to the spirit and then sent via serial to CB200 so all channels would be stabilized, in my jets I have 2 servos for ailerons, 2 for elevators, 1 Rudder and then 2 for the vectoring so I need 7 channels to be stabilized and I don't want to use Y's
Thrust vector servos are 2 separate channels that has different gain than the elevator, rudder and aileron
Regards,
Alejandro
gjhernandez
Hello Tomas
Was there any progress integrating the Aero+central box+several servos?
I would like to try Aero+geolink in a jet with FPV
