Jeti it is!
yufasa
Did I miss it before or is there a price now? 13 553,00 Kč Or around $575
Justchill
So... Availability date for the DS-12 Spirit edition to the US?
It depends how easy certification will be.
But I believe all will go well. Probably 3 weeks.
tfmcnellist
My new Spirit/Jeti radio is on order. Looking forward to the radio and the spirit RS here in the USA. It should be available just in time for me to start flying this year after a few medical procedures.
yufasa
I did not see the new Jeti Spirit radio go on order and it show backorder again or did you order somewhere else?
tfmcnellist
You can order through the Spirit Eshop even though it says back order.
Just hit the back order button and it will add it to your order.
yufasa
That did not work for me before for some reason but it sure does now! Thanks. Placing my order
duckforeman
This might be good enough to make me switch from Open TX running on an X10. There are a couple of things that are not clear to me, because of the way Jeti have purchaseable options in the firmware which enable some of the hardware features. So I would like to know if the Spirit version has all three transmitter modules enabled, i.e. two at 2,4Ghz and one at 900Mhz. Normally to get those with the standard DS12 costs significantly extra.
900 Mhz is not enabled by default, because there is not even 900 Mhz receiver yet. But in very near future it will be available and can be also connected as a backup receiver for Spirit RS.
duckforeman
OK thanks, that makes sense. What about the two separate 2.4G transmitters, are they both enabled?
