[SOLVED] Telemetry problem with Tribunus and FrSky
azaz44
@Thomas
was there any progress on this maybe?
I have same problem on all Archer GR8 I have.
On Archer RS (I use this with Spirit GT over F.Port) there is no problem.
no progress yet, but we shipped unit to FrSky.
I believe that in 2 weeks we could have some information.
Do you use F.Port on all models?
azaz44
ZeXx86 wrote:Hello,
No not all. Only those with Spirit GT, I have 3 of these. And everything works fine with those, but I'm not sure if this is because of F.Port or Archer RS. RS is different than other Archers and has different firmware.
On SBUS everything works fine with ACCST. So problematic combo is Access, Archer not-RS connected over SBUS.
F.Port is working quite differently, so there is big chance it is working because you are using this protocol.
azaz44
ZeXx86 wrote:F.Port is working quite differently, so there is big chance it is working because you are using this protocol.
This could be. But I can't use it on other helis, because Spirits are not GT.
But it also works on accst with no problems. It seems to be sth Access specific.
azaz44
Is there any update on this issue?
I'm sorry to push, but not fully working telemetry is quite an issue, and this problem is already over one year old.
I found there were updates to Archer firmwares in between, latest for Archers (all except RS) is 2.1.10.
I installed it today, but the issue is still there.
azaz44
ZeXx86 wrote:Hello,
Thomas, any update on this - very old now - issue?
azaz44
Hmm any update?
Wanted to order another GT, but I start to wonder if Spirit is still a good options for non-Jeti radios. Will OpenTx still be supported???
As far as I know FrSky has our units for years. But maybe nobody is testing their receivers with third party products.
Contact with them is very slow through emails. At the moment we have no update.
OpenTX will be supported as long as it will be used. Today we are releasing new integration update for radios.
azaz44
ZeXx86 wrote:As far as I know FrSky has our units for years. But maybe nobody is testing their receivers with third party products.
Thank you Thomas and I'm sorry if I was too impatient. You probably have too many questions to answer.
It looks hopeless, FrSky even removed firmware page with issues on github :(
