Lua-Script under ETHOS
SBUS 24 is not supported as it has no meaning at the moment and has bigger latency. So standard FBUS settings should work correctly.
Yes, I thought to myself that SBUS-24 is not compatible, which is why it was not possible to control the servos - SBUS-24 is not necessary for me either, but it was clearly evident that this is obviously a communication problem, otherwise it wouldn't have worked (integration) - For me it's only important whether you still do something about this topic or whether you say I won't put any more effort into it -
I can only say one thing, that there can be no incompatibilities on the control side, otherwise ACCESS would generally not work and would then probably not have been released for ACCESS by FrSky - the reason is certainly somewhere else, especially since the integration is included FPort works -
Thanks for your answer !
Edit:
I don't know if that was understandable, but the integration didn't work under SBUS-16!
That with the SBUS-24 was just a test to see if something would change -
So I always had the normal settings, which are also compatible with the input in the Spirit GT - it wasn't because I had always set SBUS-24!
I hope I was able to make that clear again -
