[SOLVED] Rp3-h elrs receiver. No telemetry values.
What is your Edge TX and receiver firmware? What is your ELRS radio module and what settings there?
IFHELI
1) 3.5.3
2.10.6
2) internal
3)333Hz
1:8
16ch Rate/2
Tried this today and no luck.
250Hz
1:8
Wide
Today it is all booting but HW 80A ESC just beeping and not servo movements.
IFHELI
I can swap the wires back and it all boots up fine and works ( w/ no integration / telemetry ).
I just set up two Chase 360 helis w/ Brain2, rp3-h and TX16S.I have integration and telemetry on both Chase helis w/ Brain2.
At first try your wiring was incorrect (swapping pins is really needed from 3.7.4 firmware).
Please note 3.7.4 firmware is not official yet, so it is better to send me direct messages about your progress to not confuse others.
It works flawlessly in all possible module/receiver settings we tried.
We assigned updated firmware today with hope it will work for you now.
IFHELI
Still no luck. After doing the update and swapping white and green wire the Spirit GT does not give me the blue light and HW ESC just beeps. I`m about to just give up and bite the bullet for another Nexus. I`m wasting to much time on this. I have no problem setting up a Brain2 or a Nexus with the TX16s and RP3-H. I really wanted to keep the GT on this heli but I`m getting tired of it not working.
I swap the wire back and load 3.7.2 on GT. The GT and ESC will boot up and work fine.
I download the new firmware(3.7.4) and swap wires again and the ESC beeps and the GT will not boot up or give the blue light. I can unplug the white wire from the GT and the GT will boot up but will not work and the ESC just beeps. No servo movement. It is almost like it is shorting out some how at the GT.
Thank you for your details and patience. Seems like we will need another TX16S to try to reproduce your problem.
IFHELI
More test information for you...
If I unplug the connector with white wire and RPM wire from ESC then plug in battery the GT will boot up with blue light on. The ESC will keep beeping. The servos have power but will not move with TX input. Then if I plug that connector back into GT ele,rpm,ail port the esc will boot up and all will function. The only problem then is still no telemetry / integration.
Then if I unplug battery it will go back to the same issue. Seem like something is weird in the GT.
I was wondering if you could set it up to try on my other Spirit GT I have?
I will send you the serial number for it and a Spirit II.
