problem with electronic gov, not spooling up above 49% thr
velocity90
Can 144hz easily be added? Safe to try 120? Its not a clone, its a lv100 without sensor build in.
Verstuurd vanaf mijn HIGHWAY SIGNS met Tapatalk
120Hz should be more safe than 144Hz. And 60Hz is more safe than 120Hz.
velocity90
Just got a word back from Heino, he says its 50 to 70hz! Not 200
velocity90
Will try this tonight. After that I really can't do anything different. Can I dissable the bailout so I get softstart always please?
As I said earlier, disabling bailout will unfortunately not solve your problem in any sense. There is nothing wrong with bailout and it is not even activated in your case, so disabling will not change anything. If you can verify if Requested RPM are there or not, we will see if even governor is activated - which I guess it isnt and it is reason why your problem is occuring.
There are already hundreds pilots with the current governor and are using it daily, so you do not have to worry that something is wrong there.
There is just something wrong with the configuration that we will find out.
scrambled
velocity90 wrote:Will try this tonight. After that I really can't do anything different. Can I dissable the bailout so I get softstart always please?
If you jump from throttle hold (0%) to lets say 80% flat throttle curve, you will always see a slow spoolup.
Must be something wrong with your setup?
It always works for me.
velocity90
Will check everything tonight again but tell me, How can it be im dissabling the gov for the first spoolup, and the 2nd enc spoolups its on? My hold is fine, YGE don't even initialise if it isn't.
velocity90
@zexxs do you use the progcard or stick programming to learn in the endpoints?
We are using factory defaults that are provided in the manual which correspond to 1100 and 1900 that are default settings in the unit as well.
velocity90
Is it possible banks are switching even if they are greyed out?
Ive asked before, I can't find an option to switch too the other banks in the software?
