ESC Telemetry
Yes, everything will (is) working with all our Spirit units. Our hardware is good enough to carry even more. We are doing also optimizations from the beginning to not waste any resources.
The ELE pin is unable to do serial communication. Each pin can be used only for a certain purposes.
Spektrum users can't use normal satellites for telemetry, so usage of these ports is not a problem.
akschu
That makes sense, thanks for the reply.
gabs_mex
Is it working with HW??
Coco66
gabs_mex wrote:Is it working with HW??
Go back a couple of pages.
gabs_mex
TX, it does... I thought it was with CC, and that HW didn't send the hole documentation, I skip the post what it mention that it was ready...
thanx again..
little nellie
Is there plan to integrate the Spirit system with Futaba Radio?
Technically Futaba does not offer anything similar to Jeti, Graupner or FrSky. So it is unfortunately not possible.
Only telemetry transmission is possible.
little nellie
with telemetry, what kind of data is possible to pass back via the s-bus 2? say if I plan on using a Tribunus ESC. Would the Spirit controller able to receive the telemetry data from the ESC (battery use age, voltage, temp etc) and pass it on to S-Bus 2 to be display at the TX?
mrnets
Post subject: Re: Telemetry in Brain FBLPostPosted: Thu 09. Mar 2017 16:07:11
ZeXx86 wrote:Here is some next photo from testing :)
Hi Tomas
Are those label names official, I will have to map the names for my application?
Unfortunately I can't tell you the details yet. But I believe that most common variables. Unfortunately list is limited there, so for example vibrations from the unit will very likely can't be displayed.
