We can add safety protection that when throttle is running for at least 10 seconds then it will close the integration automatically. I think now it is good, because the most pilots are using digital protocols where Throttle channel is available to the unit. We will try to add it for upcoming update too.
In any case if closing does not work always for you then it would be good to find why, because it is not normal. It could be related to used protocol, receiver, firmware of the receiver and radio. This also mean that other parameters might be not really set or there is unnecessary delay for example.
Spirit GTR mit Geo-Link: Absturz mit Höhenrettung
the problem does not always occur but you know not if its closed safely -
My used protocol is FBus, receiver is Archer R8 Pro and Archer RS (Redundancy) , firmware of the receiver is the newest available for Archer R8 Pro (v2.1.14), for Archer RS (v2.1.10) and the radio is the Horus X10S Express with ACCESS and ETHOS 1.49 on it -
The spirit settingsfile is added as an attachment, I sent that file a short time ago because of another problem which was later solved -
- Attachments
- SpiritGT_Bank_0_FrSky_FBUS_Redundancy_EULBT_310723.4ds
- (255 Bytes) Downloaded 155 times
