OpenTx integation does not work
please redownload the firmware from same URL and try it again. I believe it will work now.
Carthago
Hello Tomáš,
new try with new download, but no changes to former behavior - led out and no lua function.
Regards,
Toni
denis747
ZeXx86 wrote:FrSky replied today that they are very busy but will give us a proper reply soon.
In the meantime we have prepared workaround, hopefully this firmware will help:
http://spirit-system.com/dl/fw/spirit-fw-2.6.2.4df
It is identical with 2.6.1 except small change in the firmware for these FrSky receivers.
It works! :D
Thanks Tomas!
denis747
Here is a video of Rx8r Pro working properly with Spirit integration after updating Spirit with the new firmware that Tomas gave
https://youtu.be/6vSLM5BzdEE
Carthago
after a new download this morning it works properly here with me too - maybe I was too fast with downloading the second version yesterday and got first again.
Many thanks to Tomáš!
Regards,
Toni
duckforeman
I got the chance to try it myself this evening and can confirm that it works fine here. Thanks for that Tomas. I await with interest to see what FrSky come back with.
Cheers
Chris
denis747
Hi, Tomas, this now doesn't work with the new Spirit 2. It is exactly the same behaviour, that is if you start the LUA first then power on the Spirit 2 then it works. If you just power on the Spirit 2 unit before starting the integration LUA on the Tx then nothing works and the Spirit 2 LED light turns off. Exact same behaviour as happened with the old Spirit units and FrSky Rx8R pro before you fixed it. I thought it was something to do with the latest firmware version 2.6.4 but it isn't as I also have a Spirit Pro that I updated to version 2.6.4 and telemetry/integration works fine on that with the same FrSky Rx8R Pro receiver (I uploaded the firmware that you issued to fix it on the old Spirits a while back, maybe the Spirit 2 needs something like that?). FrSky didn't have a clue how to fix this but you fixed it on the old Spirit units. So I would be grateful if you could with this new Spirit 2 unit. Thanks.
the problem was resolved definitively. Fix will be available in the update next week.
denis747
Thanks Tomas. I have been using a FrSky R-xsr for now in redundancy configuration with a Frsky xm+, just to get integration, on the 550X but I will put the Rx8R Pro back on once the update is available. I trust the Rx8r pro more on a large heli.
