[SOLVED] srxl2 AR6610T
10x
Are you powering up the receiver with a battery? when connected to the PC.
HeliMLM
... and is Spektrum Programmer App logged into your Spektrum account? (left, upper) there should be written "Logged in as" & your Spektrum account (first) name...
cheers
Michael
Joker
i have tryed with and without a battary.
without a battery i have put the check "power cabel"
an the receiver is slowly blinking.
Joker
now it works :D
I first connected the cable to channel one.
Then I connected it to the bind channel. :lol: :roll:
Thanks to for help! :)
10x
Well done, As you found out it needs to plug into data port and will work with the spirit through this port. But if you use a 4651T as a sat with the 6610T you will need to use port 1 to the spirit....
Joker
ok,
thank you for the information.
but port 1 is for the gas channel right?
10x
If it see's a srxl2 signal within the first 500Ms it reverts to SRXL2..
Correction from Chris: It is 200ms....not 500ms..
Joker
hanks good to know :)
chris_0815
10x wrote:If it see's a srxl2 signal within the first 500Ms it reverts to SRXL2..
Small correction: if a device wants to communicate via SRXL2 on the throttle port, it must answer within 200 milli seconds.
If a SRXL2 receiver does not get the handshake within that period, it will revert to "normal" PWM mode, see Specification for Spektrum® SRXL2.
chris
HeliMLM
@10x... as you are 'playing around' a lot with srxl2 too... did you test failsafe? how is your experience? as i my parallel thread... i am in trouble with it not working :shock:
cheers
Michael
