ESC Telemetry
flydus
Great news that the telemetry link becomes available soon. Hopefully the whole spectrum of values like with the jLog becomes available in the future.
Thank you Thomas
Gesendet von iPhone mit Tapatalk
No problem.
What other values you can see with JLog?
gerry
Hello Tomas!
The following values are output from J LOg2.6 and Cosmic / Jive Pro:
1.RPM
2.mAh (capacity)
3.Battery Volt
4.Motor Ampere
5.RX voltage
6.Bec Volt
7.Bec Amp (only for Cosmic)
8.Temperature Fet
9.Temperature Bec
If that were possible, the J LOg come out with us all and are replaced by the cable.
The cables should have a total length of 40 cm.
1.The part from the 5-pin white plug to the Y distributor 30 cm (5-pin connector)
2. The part from the Y distributor to the Spirit (3 poles and 1 pole) about 10 cm, these JR plugs we would also ourselves to the correct length Krimpen.Einfach only the empty plug.
Greetings, Gernot
Please ask if this is possible?
Greetings Gernot
For sure all the values can be displayed also by Spirit.
I guess that RX voltage = Bec Volt.
Regerding connectors, you can change it as you want. You can already buy the cable in our eshop.
flydus
Screenshot aus JLC:
gerry
Good news!
Sorry the RX voltage comes from the Jeti receiver, has nothing to do with Kontronik.
Bec Volt ond Bec Ampere come from Kontronik, whereby only the cosmos the Bec Ampere issues, why this is so we do not know?
With the cables it would be good if you can make them longer, the extensions are always error-prone?
Greetings, Gernot
Greetings Gernot
gerry
Sorry PWM I had forgotten !!
Greetings Gernot
gerry
The respective maximum and minimum values are stored, recorded and displayed by Jeti itself!
As it is with other stations I do not know!
Greetings Gernot
gabs_mex
Hello, is the Tribunus compatible yet or will have to wait for the new update and what is the ETA??
What connection will the Tribunus have to use to be compatible with spirit pro
http://manual.spirit-system.com/index.p ... _telemetry
It will be available in few days, probably this week. Cable is in our eshop available for more than week.
