ESC Telemetry
nenno
Hello...
are there Plans to implement the Kontronik Jive HV (non Pro)?
Regards - Nenno
Voodoo 600 - Compass Warp 360 - Mikado Logo 480xxtreme - FrSky Horus X10S express
yes. We will need to get some Jive for testing, then it will be added.
nenno
ZeXx86 wrote:Hello,
Did i say that i love my Spirit-FBL :D
Nenno
gabs_mex
ZeXx86 wrote:Hello,
http://manual.spirit-system.com/index.p ... _telemetry
It will be available in few days, probably this week. Cable is in our eshop available for more than week.
I it needed the Telem UNI cable, or can I make my own adaptor??
also for the Scorpion Tribunus, for what i understand if we use telemetry the slave cable will not send RPM data, can you confirm this...
terhoutd
Is there any plan to have HW v3 ESCs to be supported for the telemetry feature?
I guess the protocol is just slightly different to v4 and that it would be very easy to implement. You would just need to ask Hobbywing. jLog for example supports HW v3.
nenno
Hi...
... is it correct that you can't use Kontronic-Telemetrie with Graupner Hott??? The Sys-Port on the Spirit is already used by the Graupner-Telemetrie...
Nenno
gabs_mex: You can make own, ground and signal is directly connected, BEC (+5V) is not connected at all - very important to not connect. Both red wires are not connected - floating. In the Spektrum connector wires are as usually, brown in the middle.
terhoutd: HobbyWing v3 supports only RPM readout which Spirit already support.
nenno: With the version 2.4 it will be not possible, but later it will very likely work
terhoutd
thanks I was wrongly under the impression that the HW v3 escs were also sending amps and voltage :(
Goody63
Just wanting to clarify what the telemetry capabilities are / and what I need to enable telemetry on the following escs for display on my Jeti through the Spirit;
Castle Ice2 - can provide RPM and telemetry with the CC adaptor (http://store.spirit-system.com/en/acces ... cable.html)?
Hobbywing V4 60A - can provide RPM and only voltage telemetry with the HW adaptor (http://store.spirit-system.com/en/acces ... cable.html)?
Kontronik Jive 100A LV - can provide RPM but no other telemetry?
I think I understand that they should all be able to display RPM to my Jeti (by using the governor option and pit pin) and the telemetry for the HW and CC Ice2 escs just require the additional cables to the Spirit?
Thanks for any advice.
Goody63
Should I be able to get telemetry from the Hobbywing 60A Platinum V4? I connected the cable, enabled telemetry in the Spirit firmware and found the values on the Jeti. However it just wont display any actual data?
