Problem updating firmware.
Adeezy9183
Just got a used goblin 380 bnf with the spirit FBL system. I downloaded the spirit settings software and hooked up the spirit To it. Yes, it was connected but upon connection, I got a message saying that my firmware and software didn't match. So I went to the spirit website and downloaded the new firmware and just to be safe I re-downloaded the software. Connected again and when I try to find the firmware file to flash it, the file is not available to select. Can anyone help me out with this?
The problem can be that your web browser is renaming firmware file.
It should end with "4df" extension. You can try another web browser or rename the file.
This should help you. Also before update, make sure that your driver is installed from our software (in case of Windows) or from the URL in the manual (for OSX).
Adeezy9183
Thanks! That worked! Now to figure this thing out. Thanks again!
