Setting Spirit up with different RX (EX-Bus)
W.W.
is it possible to set the Spirit up with a different RX (RSat or R9EX) than the RX, which will be used in the helicopter? Or do I have to redo the adjustments of the servo travel?
I wan't to replace another FBL-System in my helicopter and want to play around with the Spirit and the Jeti Integration first, before flying.
I think, with digital signals like SRXL/SUMD/UDI/EX-Bus the values shouldn't Change with a different receiver.
I will go through the settings anyway but want to know whether I shold invest the time in adjusting servo travel ... precise when playing around or if I should save the time and do this in the model.
best regards Wolfgang
regards Wolfgang
If you are changing receiver, but used protocol (for example EX Bus) is same, then everything should be same. So you do not have to reconfigure anything.
W.W.
many thanks, great support and fast answers here!
regards Wolfgang
