[SOLVED]Problem with Spirit Pro-initialization doesn't work?
MarkusD
Hi all,
I have an issue with my Spirit Pro - used it 3 flights in my TDR so far and wanted to fly more to adjust parameters but it didn't work....
What happened ?
I switched on my DC 16, the buffer LiFe and then main battery on the Kosmik. The Spirit starts but the swash moves down and up and remains in an "up" position.
Pitch doesn't show any reaction but all other controls work just fine....I couldn't get it to work on the flying field. Now at home I still can't see the reason for my issues.....also searched the forum & read the manual.
Spirit slowly blinks upon start and then turns into permanent red
My Heli:
TDR 1, Pyro 700 @ 12S, Kosmik 200, 3 x BLS 451 & 1 x BLS 251
Hope somebody can tell what happened....
BR
Markus
I will contact you in a private message.
I believe we can find an answer and solution soon.
MarkusD
Hi Tomas,
thank you for the quick feedback - I feel sorry for having to bother you already 2 time due to problems......
But support is excellent and the Spirit flies already very very well ;-)
BR
Markus
MarkusD
Problem solved - thank's to Tomas !!
It was a permanently engaged RESCUE by a defect Switch on my JETI DC 16 (which I thought was reliable)
BR
Markus
