[Solved] Jeti REX7 - Received Frame was corrupted
Thorvald
I have been noticing the odd message in the Spirit log stating "Received frame was corrupted". It is not constant and only appears a few times randomly while testing on the bench.
With the current state of Jeti and Spirit (and knowing how ExBus has been so far), should this be expected or should there be absolutely none of those messages in the log?
My config:
Jeti DS16 (Tx set to 100hz)
Spirit.bin v2.01 (download from this site not from Esprit lol)
REX7 firmware 1.02
Spirit Pro 2.01
EXBUS single wire connection
Thorvald
Well had my maiden today with Spirit Pro and it was thankfully un-eventful.
I suspect these messages were due to the Tx being too close to the Rx (all on the bench). None of those errors appeared in my first log.
Will keep an eye on it though.
With REX receivers it is unfortunately normal (if it is not frequent) and it can appear especially if you are in the Jeti integration menu.
In the flight there should be no problem.
Thorvald
A number of flights under my belt now and I've noticed it is only when the Tx is really close to the heli, so I'm not too worried. None in flight.
I'll mark the thread as solved.
Cheers
Tim
