It's like Expo on Pitch
torro
Hi there,
Made some flights now. Played with style and cyclic feed.
I noticed, that Pitch feels like with Expo on it. Had 12,5 degree cp and need a Lot more way on the stick than before with a brain.
Is there a setting that could explain this behaviour?
Thanks, Flo
Spirit unit transmit pitch signal directly without any modification.
This mean that there can't be any influance by the unit.
What is possible that your previous configuration with Brain affected collective pitch channel in some way.
Or if your helicopter is after crash, some head bearings are faulty.
You can use Pitch Pump Booster in the unit to make pitch control more agressive.
torro
hi,
affects pitch boost only fast stick movements or is that a kind of expo for pitch?
Yes, but it can feel similarly as expo on the pitch channel.
All in all, the unit does not use Expo in any channel, unlike other FBLs.
torro
ok, i´ll try.
