[SOLVED] ESC Plug Port
kumoro
Just finished setting my Spirit Pro with Jeti integration. Just converted from BD 3SX Maidened today and it was very very stable. Tail hold solid, this is very different with 3SX when I had a constant tail wag.
I need assistance here, maybe this already covered, but I can't find it. Right now I plug my esc into Rx (Jeti EX R3). I tried to plug esc in to Aux1 port, the motor only emits beep sound and it was not armed at all, so when I give a throttle input, nothing's happened. As to my knowledge, the esc or bec should go in to FBL system, and not Rx, since FBL System uses more power than Rx. But, I can't follow this. I plug my ESC into Rx port.
Assistance and inputs are needed here.
Thank you
to use Throttle output from the unit, you have to assign Throttle function.
This can be done in the General/Channels.
Assign Throttle function to channel 1 and then, all should work fine. Plug the ESC to AUX (AUX1) port.
It might be needed to change throttle range (or calibrate the ESC) but that's all.
kumoro
Is it on the computer or on the Rx?I believe in the Computer since I can't find any option Channel on the Rx.
Yes, in computer - in the configuration program.
There is tab called General and button called Channels.
In default settings, Throttle channel is unassigned.
kumoro
Great, problem solved.
Thank you very much.
Perfect, no problem.
