Been using Jeti & Spirit Pro for about 6 packs of battery, that is about 20 minutes of flying, so I am consider new to this system. With spirit, mine flies greater than my BD 3SX. The terms here I still dont understand are :
1. Bank, what is that and how to set it (connection) and setup in the software. Is this can be done on Jeti Tx?
2. Gov, I use Hobbywing Platinum 60A v4 that has RPM output. Where should I plug it?I read on the manual, that it goes to middle pin on the ele/pit/ail, while on the ele/ail/pit I have signal cable from my Rx (I use Ex Bus). Can it be joined there, I mean, one plug from Rx goes to inner plug while RPM output from ESC Goes to middle sensor?If I, say, set the max head speed to 2500 and I set 85% on the Tx, would I get 2125 rpm??
Thank you.
