Wizard -TDR II?
Franky13
Hello!
Under Setup Wizard , there is the TDR Heli . making it the TDR II meant ?
I need a setup for the TDR II !
Thank you!
Greetings Frank
you can use Default preset.
Then you can set Rudder Common Gain to 1,3x
Pirouette Consistency to 185
Rudder Delay to 0-5
Elevator Filter to 4
For TDR 2 I recommend to decrease Geometry 6° by 10-20 points due to a different Head geometry.
This will improve behavior a lot and reduce possible bouncing.
