hi,
first, i didn´t change anything, just did the update
when gov is enabled, the motor doesn´t start.
when gov is disabled, the motor runs immediately after switching the switch.
ESC is calibrated, values in spirit are 0 and 100%
log is clean
any idea?
ESC is a YGE160HVK
thanks, Flo
next gov problem after update 2.1
what will happen if you will wait little bit longer?
Was the ESC recalibrated after the update or something else?
If completely nothing was changed (except firmware), it should work in the same way as the old firmware.
Good. Can you please share your settings? At least for Bank 0.
here it is
- Attachments
- B0D700.4ds
- (255 Bytes) Downloaded 113 times
thestructured
I had a similar issue on 2.1 where the governor was not engaging at all until I set the spoolup rate to fast
Thank you for the info.
I am glad it works, although it is little bit strange as the starting procedure is very same with previous firmware.
Increased spoolup works similarly as when you increase Throttle Range - Min.
