[ Version 2.3 released! ]
Version 2.3.0 was released!
It brings many new features and improvements:
  • Brand new Graupner HoTT integration:
    • Full integration with HoTT radios without any limitations!
    • Computer is not needed at all!
    • Configuration anywhere and anytime directly in your radio.
    • Works with a different Receiver protocols - PWM, PPM, SRXL/SUMD.
    • Support for nearly all HoTT transmitters (all with display).
    • Telemetry support out of the box.
    • No need to update transmitter or receiver.
    • Ability to display Current RPM even without enabled Governor.
    • Big thanks to Graupner and TomasN.
    • For more info please check the HoTT integration guide.
    • NOTE: Support for Spirit Aero confirmed.
  • OpenTX Integration:
    • Added full support for Telemetry - unit will provide own data.
    • Vibrations visible as Fuel and Current RPM as RPM.
  • JETI Duplex Integration:
    • Full support for DC-24.
    • New special function "F: Stabi function" added.
  • Graupner SUMD protocol:
    • Channel mapping was modified so that no assignment changes are needed from clean radio profile.
    • Channel travel and reverses were modified so it will fit out of the box with clean radio profile.
    • NOTE: Radios MX-12/MZ-12 will require to set Gyro Gain to Channel 7 in the Channels.
  • Rescue and Stabilisation activated by a Separate channel:
    • From now you can select which way you want to activate Rescue or Stabilisation modes.
    • You can select any available channel for activation.
    • New special function "F: Stabi function" was added for this purpose.
    • Very easy configuration described in our Guide, including old way.
    • Old way (by Negative gyro gain) is without any change.
  • New Vibration Analysis:
    • Vibration Analysis was rewritten for improved Look and Feel.
    • New inteligent detection of vibrations and part recognition - during measurement you will immediately find which part is responsible for vibrations.
    • Reduced CPU utilization and improved response on some systems.
    • Plots saved in the Vibration Analysis now contain Axis label and Vibration level.
  • Governor:
    • Added utility for Sensor signal verification - You can easily check if the signal is valid or not even without running motor.
    • Current RPM is displayed even without Governor enabled.
    • Added new Governor section to the Wiki.
  • Improved Setup Wizard:
    • Setup Wizard has more usefull hints for beginners.
    • Links for manual and guides embedded in the software.
    • Profiles are ordered alphabetically.
    • New Profiles: Gaui X4, Gaui X5, Gaui X7, Soxos 550, Soxos 600, Soxos 700, TDR2, LA600, Logo 800XX, Diabolo 550, Triabolo 700, Protos 380, Goblin 420.
    • Update of the previous Profiles, especially the Rudder Delay decrease.
  • New Servo List:
    • New comprehensive Servo List specially tailored for Spirit units.
    • Any missing servo will be added to the list.
  • Software enhancements:
    • Connection stability with the Wifi-Link module was improved, especially during inactivity.
    • Diagnostic tab is now displaying current mode more clearly - Head-Lock+Rescue, Head-Lock+Stabi., Normal, ..
    • Diagnostic tab is now displaying Unassigned state for Throttle and Banks when unused.
    • Software can distinguish Spirit Aero unit and provide according help.
    • When there is a problem during flashing, more helpfull instructions are provided.
    • When configuration is not saved during Bank channel assignment during Bank Comparison, window is not displayed.
    • Software can open http links in a Web browser.
    • When firmware and software versions are not matching, more details is displayed.
    • OS X: Link for driver is easily accessible before Firmware flashing.
  • Wifi-Link module:
    • Support for the latest 2.3.0 firmware.
    • Stability improvements in the Web UI.
  • Wiki Pages:
    • Front page of the Wiki was redesigned to get overall overview.
    • Improved manual graphics style.
    • New Wiki pages.
You do not have to change any settings after the update from previous version.
Graupner SUMD users will need to update their channel mapping, channel reverses and travel to default.
Update for the Spirit unit, Wifi-Link and Jeti Integration is available in our Download section.
Firmware 2.3.1 was released!
This update is only minor update to improve the HoTT integration experience.
All pilots that do not use this feature can stay with 2.3.0.
  • Graupner HoTT integration:
    • Fixed compatibility issues with other telemetry sensors.
    • Fixed integration menu glitches in a rare cases.
