[SOLVED] flysky FS-6ix transmitter
alchemy66
Hi all, just received my Spirit Pro which is going on a Devil 380. I'm not new to helicopters but I've hit a problem with this Flysky tx which I hope someone can help with.
It says in instructions all swash mixing must be disabled in the transmitter and to use H1 or single servo setting. I do not have either of these options. This is what I have...
Helicopter fixed pitch
Helicopter variable pitch
Helicopter 90 degree
Helicopter 120 degree
Helicopter 140 degree
I have set it to fixed pitch which when the throttle stick is moved only channel 3 responds, am I correct?
Thanks.
I think that the correct settings is:
With the col. stick you should be able to control 2 channels in default settings.
Then you will just set the Throttle curve to for example flat curve if you are using governor.
alchemy66
ZeXx86 wrote:Hi,
Ah, ok that makes sense, I have changed to variable pitch and now get channel 3 & 6 moving on throttle stick. Thanks very much.
James
Great. Now you can try to change Throttle Curve and it should work OK.
alchemy66
Yes thanks, I will no doubt be back for more help as my build progresses.
James
