nitro Govenor Sensors
SirCyber
I have a OS 105 HZ-R in a Raptor 90 G4.1
Now I would activate the Govenor feature and searching now for a sensor.
The motor is having a backplate mounting hole, but i can´t find a sensor.
you can use for example Spektrum backplate sensor, but you will need to set a proper distance which might be uneasy.
Easier can be to use a Hall sensor such as Align.
You can take a look here for the guide:
http://manual.spirit-system.com/index.p ... RPM_Sensor
