When there's a serieus log entry is there now led support ne
velocity90
Been away from flying for a while and I'm 2 firmwares behind. When there's a serieus log entry we used to get a different swash initialization dance which is difficult to see on the field. There where requests to also have the led show the error. Is this feature implemented yet?
Best regards,
Verstuurd vanaf mijn U FEEL PRIME met Tapatalk
not yet. LED is unfortunately much less visible than the servos itself. You can hear and see the servos and rotor head from far. While the LED is visible just in the certain angle from close proximity (and in some cases is not visible at all) so without carefully checking the LED each initialization, it can't be better indicator of the saved log in our opinion.
Regarding servos, we recommend to always verify that all servos are properly responding as the pre-flight check procedure. This include also observing what the model is doing during initliazation.
Or do you think it will be more visible with LED? Please let me know.
velocity90
Hi, during initialization I think some sort of led blink sequence is easier to see(or constant flashing) . But the swash dance is ok too.
