[SOLVED] SpiritPro software via DS 16 not adjustable ...?
Franky13
Hello!
Why can not I set the Spirit software on the DS16?
If I start the Spirit software under Windows 10, the Spirit software will open and I can perform settings!
But when I bind the DS16 with the Spirit, I can not open the software under Windows ...?
How should I adjust the servo drive?
Software Version: 2.4.3
Greetings
probably you have configured Kontronik Telemetry.
Then this behavior is correct - see the Telemetry window.
Franky13
Hello!
No, I have a Hobbywing 130 controller
Can you please send me your settings?
Can you enter the integration and also control the servos normally?
Franky13
About the DS16, I can adjust everything!
If I connect the Spirit with Windows 10, DS16 and Spirit are on, the Spirit software will only open the demo mode?
TDF - First Setup.4ds
My settings!
(255 Bytes) Downloaded 92 times
Thank you. So it is exactly like I was saying.
You have configured Kontronik telemetry. This is reason why it does not work.
When you have configured the Kontronik telemetry, there is big warning that this behavior will occur.
So you can simply go to the Advanced/Telemetry and change to Disabled or HobbyWing telemetry. If there is Kontronik Kosmik/Jive PRO this behavior is correct.
Then all will work!!! :)
Franky13
Thank you!
That was my fault.
I have taken the data from another heli that had a JivePro.
