jeti radio spirit system and servos
Helichef
hi I asked this question in the wrong section I think this is the correct area now.
heli tail servo and the others not moving after the initial set up process is done in spirit wizard.
I think I read somewhere some time ago about doing something in the radio cant quite remember what it was.help needed
is LED on the unit steady ON?
Were the servos moving at any point?
Normally there is no reason other than that the servos are plugged incorrectly in the unit.
You can take a photo of the connection so we can check it.
Helichef
hi I'm using a r7 plus receiver only rudder is moving I have stsndard classic receiver checked in the set up section but when I reach to the servo set up section nothing happens
At that time the wizard is still not communicating with the unit so it is not important what you will select in the software.
I think that problem could be in the connection of the servos.
Can you take a photo of the unit with connected servos, please?
Helichef
Helichef
I hope it's clear enough
Thank you very much for the photo.
It looks good.
Did you selected PWM connection type in the Setup wizard?
What I can recommend is to use UDI or EX Bus connection, since it is digital connection.
With EX Bus you can also get full integration with the Jeti radio - it is just one cable instead of 3.
Helichef
Im sorry how can I do that or should I go to the connection page in the manual?
