Question on mounting the Spirit
ryguy76
I am finishing up on a new Oxy 4 build and noticed that the boom clamp has a slight seam between the mating pieces. If I place the Spirit in the middle of the boom clamp, I can rock the FBL from side to side slightly due to the high center of the seam. I had used the white foam tape to mount the Spirit and it looked a little off-level to the eye. Is this something that really matters? Does it need to be perfectly level or is this my OCD getting in the way?
Thanks in advance.
in that case it is better to cut two pieces of the tape and make a kind of rails under the unit.
so that in the middle there is nothing.
More precisely the unit is mounted, more precisely it will fly.
ryguy76
Thanks Tomas.
