Spirit FBL in front of the rotor shaft possible?
Kluftinger
I'm planning to buy in the future a "Heli Baby NT" from Minicopter.
This semi-scale model has no special surface for a gyro behind the rotor.
Does the Spirit FBL need to be behind the rotor shaft?
In the manual is a picture, where the system is vertical aside from the shaft.
Can it also be under the pilot seat of the Heli Baby vertical in front of the rotor shaft?
yes, it can be anywhere. Mounting surface must be only very rigid and perpendicular to all 3 axes.
