Geo link map shows a sector very far away
tabbie
Hi, should the map in the Geo link system page shows the actual position? And should the map automaticly find the right place?
After setup it shows a map position about 50km away and it is not moving automatically.
Pking
Use the home button your are probably using the isp button.
The isp button is to start you not too far of where your are connected
Envoyé de mon iPhone en utilisant Tapatalk
tabbie
Hi all, yes I pushed home button but there is only a black screen. When I push ISP I have a map from a position far away and when I move the chart I come home to my place where the Heli stands. But again when I push home the chart is away and I have a black screen.
Addendum: what are the colours meaning ( the ring at the position has 3 different colours.)
the map will show you your current position if there is GNSS signal, but it will not get you automatically there.
This is work for upcoming update :)
