Preset settings for T-Rex 470LM
lottermann
Hi all,
This is my first post.
I am from Germany and hope my English is reasonably understandable :D
I am actually starting again because my last helicopter flight is about 25 years old
It´s my first set up with the Spirit FBL (and my first FBL)
I would like to get the preset settings für the T-Rex 470LM without running the setup procedure.
Is there an option to get an .4ds file or a list of the settings?
Here are some informations about my hardware.
Hardware:
SPIRIT
T-REX 470LM standard motor
3x Align DS450M
1x Align DS435M
HW Platinum Pro 60A V4
Graupner Gr16 (SUMD OF 16) / MZ24
Telemetrie and ESC connected
Many thanks and kind regards
Dirk
Hi Dirk and welcome in our forum!
For your helicopter you can select Trex 500 preset in the Setup wizard - in Spirit Settings software.
But regarding loading preset from someone else it is not that easy.
If you will load it you will still have to set at least some important parameters - especially Subtrims in the Servos tab.
And also setup of someone else must be completely identical to yours.
So I recommend to use the Setup wizard and to try it yourself. You can ask for any detail if something will be unclear.
lottermann
Thanks for the answer.
I will use the setup.
if there is the possibility of a support in german language?
Things are difficult for me to explain in English.
greeting
Dirk
Yes, you can write in German language. But I will have to use translator, but I hope it will be understandable.
lottermann
OK. I'm currently traveling a lot for work.
If I find time again I will configure the system. If you have any questions or problems, I will contact you.
Many thanks in advance
greeting
Dirk
