[SOLVED] Mounting spirit with connectors down
SethML
I'm installing my Spirit in an Align Trex 250. The only good place to mount the FBL is upside-down, with connectors facing down. Chapter 3 of the Spirit manual says that "The unit can be mounted horizontally so the connectors face upwards" or on the side of the model. Is it possible to have the FBL mounted with the connectors facing down? I'm hoping I can convince it to work. If so, the manual should state that this is possible. If not, consider it a request for the next firmware version.
it is possible without any issue.
W.W.
Is this true for the Spirit pro too?
regards Wolfgang
Yes, it is possible.
