[SOLVED] Changing blade size , any impact on spirit pro
Karl1081
I'm fitting a new set of 696 rail mains and 116mm tails to my goblin 700 t line.there replacing 710 sab mains and 115 tails. Will the spirit pro need any adjustment after these new blades are fitted. the tails are approx the same size ,so gain shouldn't be affected but there's a little more size difference in the mains. I'm hoping not as my bird is flying great at the moment
it is hard to answer, because even if size is exactly same just changing to a different brand can make very big difference in flight behavior.
But generally you do not have to change anything.
Usually change from less aggressive to more aggressive blades can cause a troubles. In other way it is getting better.
Karl1081
ZeXx86 wrote:Hello,
hi
tested the blades and heli flies just as fantastic , no setting have been altered
thanks for your reply
