Difference 6 degrees geometry to 4.5 in TDF ...?
Franky13
Hi Tomas!
Please explain to me why the 6 degree geometry should be set to 4.5 on TDF.
What is better at 4.5 Geometry, what are the positive effects of the change in TDF?
Or can adjust other parameters to get the same effect?
Thanks for answer!
Greeting Frank
TDF has not standard geometry and because Geometry 6° is counting with standard geometry it require different configuration for linear servo travel.
If value is too high then you will get unwanted oscillations and problems with elevator.
No, you can't achieve same settings with other parameters.
mb-1953
Would this also apply to the tdr2, which also uses linear linkage.
Yes
