Problem mit Telemetrie sensoren
gerry
Hello Tomas
We have a problem with the sensor detection of the Spirit ais telemetry sensor in a Lua App. All common sensors are recognized and can be selected, just not the spirit. Since you are also a programmer, I thought, I'll ask you if you have one Idea, why we have this problem. The telemetry coming from the cosmic about the spirit in the Jeti transmitter is indeed displayed by Jeti, but not in the app, why? Please ask for your help.
LG Gernot
Greetings Gernot
gerry
we have come to the conclusion that all common mass sensors have a name in the sensor menu at Jeti, for example Mui, Unisence or Mezon, the Spirit has no name and that could be the problem
Greetings Gernot
if you are using Kosmik telemetry then this is the problem. There is known issue that Kosmik is causing troubles in Jeti receiver.
By disconnecting the Kosmik from EX port it will work again.
Solution is to wait for Kosmik update or to use new TelMe telemetry that is introduced in the upcoming 2.6 version. Then ESC telemetry cable is connected directly to the unit and everything will work.
Maybe I dont understand the problem. I dont know what Lua App do you have. This is matter of developer that is making this Lua App.
