frsky integration and holding limit
leatherface
hi,when i use frsky integration holding limit always displays 0.if i change the value to say 50 and then save it,when i go back in to governor menu it will be zero again.not sure if there is a bug or not,hopefully can be solved.thankyou in advance.
very likely this is because your scripts or Spirit firmware are outdated.
After update it should be all fine.
leatherface
thankyou very much,that was it.
