geo+4649T+sats
fastang
Can someone tell me the best way to wire a GEO + a spektrum 4649T + as many additional regular spektrum sats as possible to a Spirit Pro?
I have the 4649T and its cable, the Geo and its cable, the Pro, the Jeti cable, a Spektrum multi adapter cable.
The heli is a Trex 600 and is currently setup and flying very well with just the Spirit Pro and 2 regular sats. I would like to add the Geo and be able to pull telemetry from the Hobbywing 120 with the 4649T to view on a DX7. I would like to run the 4649 and at least 2 additional sats but the way I see it, the 4649 and the spektrum multi adapter cable will occupy the same terminals.
So how do I wire this all up and still be able to use 2 regular sats along with the Geo and 4649T and please be specific of the placement of each and every wire. Im very new to all this so please dont assume I know where something should go!
Many thanks!
Mike
Juan Cobo
I believe that if you can, in my oxy3 I have a satellite, spm4649t and geo-link with a Spirit;
spm4649t: (-) (+) RUD and ( ) AIL
satellite: (-) (+) ( ) RUD with voltage regulator for 3.3v
GeoLink: sat port
The spirit pro has another sat port there.
with HobbyWing ESC telemetry and GeoLink together you can connect just 1x SPM4649T + 1x Spektrum satellite.
You will need Jeti integration cable which is connected according this guide:
You will have to do just one small change - instead of using RUD port for powering the SPM4649T receiver, you can connect it at other free port such as AUX2.
Then you will need the Spektrum Adapter V2. The Spektrum Adapter will be connected at the RUD port.
And that is all you will need.
