Mounting Tape
omarb
Hi Guys,
Need some help. Will this tape work for mounting the spirit fbl? Reason being here in SA the only people that have 3m vhb want over $100 per roll.
They have Gorilla mounting tape as per below which is priced ok and easily available.
https://www.builders.co.za/Fixings-Fast ... 0000639632
Sent from my SM-G935F using Tapatalk
Unfortunately we can't answer this question, but mostly any tape that is not too thick will work. Thickness should be near 1 - 1.5 mm.
The unit should not move at all at the model.
omarb
Ok... will try and revert. I think it's a 2.5mm tape.
