Missing cable? Uspirit
Tgilf
Hi
I want to configure my uspirit with frsky x4rsb.
I have one jst cable connected to usb and one used for Power from ESC. So i am missing another mini jst adapter cable to connect the receiver (x4rsb) to the uspirit.
Can i use one ob These https://www.live-hobby.de/Servos-Zubeho ... 18200.html
Please help me.
My uspirit came with 2 adapter cables
Tom
yes, there are two supplied cables.
JST-RX for connecting uSpirit with your receiver.
JST-SERVO for connecting the USB interface.
If you will connect the ESC to your receiver then everything will work immediately.
Unfortunately I can't confirm if the cable is fine, from the photo it look like it has wrong +/- polarity at the JST connector side. With a needle it could be fixed.
We have all the cables available in our store for very similar cost.
Tgilf
Thank you very much. Power to the receiver is working Fine for me.
One more question are the two supplied cables you mentioned identical? Or how can they be seperated from each other?
ZeXx86 wrote:Hi,
No, they are not identical.
You can see difference at the servo connector side.
Please see our eshop https://store.spirit-system.com/en/14-accessories
to check what is different.
JST-SERVO can work as servo cable adapter and JST-RX as cable between Receiver and unit.
Tgilf
ZeXx86 wrote:No, they are not identical.
Thanks but i could use the servo cable adapter in combination with servo patch cable as link to Receiver?
